RCU Forums - View Single Post - HELP! OS 46LA reverse!
Old 11-08-2008 | 05:54 PM
rsands2801
Default HELP! OS 46LA reverse!
i dont know if this was my error but i doubt it...i had the engine running earlier and was perfect (running it in..barely had 10 mins on it)
Suction is rediculous to the carb for glow fuel...i check fuel lines and they are in correct order (blow in tube from exhaust it goes out carb line and blow carb line nothing out exhaust line)
so went out tonight to run it in a bit more and flick started the engine...started BUT was spinning the wrong way...now maybe i am living in fairy tale land here but the wind was rushing forward in the wrong direction. what happened?
prop is on the right way...earlier today it worked fine. i spin counter clockwise as normal.
