ORIGINAL: altavillan
It's just to test if your prop is too much for the motor system. If any thing feels uncomfortably warm or you can't leave your finger on it then reduce the size of the prop. Then the props you already have can be used.
Nothing to do with, will it hover, more like will it burn up.
yeah I know what you are saying about the heat and the concern of blowing the motor, just asking if the motor has enough thrust with those props to hover or do other manuvers.
