RCU Forums - View Single Post - my
Thread: my
Old 11-09-2008 | 12:43 AM
ChuckW's Avatar
ChuckW
Default RE: my
It does sound like the carb is stuck. This happens when engines sit for long periods of time. the castor oil from the fuel gums up and makes things stick. You could also have a little corrosion present. Depending on how bad it is, you might be able to get things going with a little automotive carb cleaner spray or it may be bad enough that it requires a complete tear down and cleaning. I've seen them both ways.
