First of all, bear in mind that I didn't "modify" the BUSA structure but rather trashed it entirely and built a new fuse almost completely from scratch based on the Joseph Nieto technical drawings, which I had blown up to match the BUSA wingspan. I don't think I'd recommend this approach, particularly on a first model.
With this in mind, the rudder and stab/elevator on the EIII were referred to as "full-flying" meaning there was no stabilizer or fin as on the BUSA version. Doing a full-flying rudder would be a fairly straight-forward modification. The full-flying elevator is a bit more elaborate and also makes the model a bit harder to fly. Note that both the rudder and stab/elevator on the BUSA eindecker are considerably larger than scale. I also moved the wing position forward to it's scale location. You'll need to think hard about whether you want to mess with the aerodynamics of the model.
ORIGINAL: Tuskegee1973
As of now i'm just going to build and make simple modifications to the E III.
I think this is wise. You seem to have both the skills and desire to do serious scale building (and I welcome you to this teeny fraternity) but you might be better off just playing around with basic mods on the BUSA kit. You've already got a great start on that with your built-up fuse structure.
I have a question for you...I saw your tail assembly as well as your tail skid (custom made?) and I love it!
Thanks, the tail skid support is one of the characteristic features of the EIII so I wanted to replicate that. The basic structure is music wire in styrene tubing.
...it's not connected to the fuse the way it is per BUSA plans. I'm assuming you made the "mount" first and then went with modifying the tail feathers/rudder?
As I said, I completely scratch-built a new tail, elevator, and rudder and had to come up with my own mounting methods. The rudder is mounted on a modified tail wheel bracket. A music wire runs through the bracket, through a tube in the rudder and into the skid brackets below. The full-flying elevator is built around a central aluminum spar that slips through a styrene tube which was then attached to the rear of the fuse. I was probably naive in doing all this which was also my first RC build.
