RCU Forums - View Single Post - Does anyone know the dynamics of a shrouded prop?
Old 05-29-2003 | 11:54 AM
MajorTomski's Avatar
MajorTomski
Default Does anyone know the dynamics of a shrouded prop?
The principle purpose of a shrouded prop is to eliminate the vortex ring generated at the tip of the propeller. There is a component of this ring that disturbs the airflow be hind the propeller and drops the efficiency. The trouble is that the struts needed to support the shroud cause as much negative effect as if you didn't use the shroud in the first place.. I fly a 13 foot R/C advertising blimp and the two main lift fans are shrouded. On a wood 6x3 prop I gain about a half ounce of thrust off each prop in the ducts.. In my case the shrouds primary purpose is to keep peoples fingers out of the blades
