RCU Forums - View Single Post - P120 FUEL FAILURE
Old 11-09-2008 | 10:59 PM
jetfreak
My Feedback: (9)
Default P120 FUEL FAILURE
Mr Matt,
I have P-120 that has 2hr 34min runtime on it that rec'd a fuel failure today about 3min 43s into the flight. Caused some minor damage to the airframe as I was unable to make it back to the runway. It was straight and level flight, about 73k rpm. I did not see the "white plume of smoke" to indicate an air bubble. Last off condition was "fuel failure". I checked the parameters that show the last 8 seconds of flight in .2 second intervals. Throttle stick never changed for those last 8 seconds. (pulse width the same all the way through). I am showing you the last 8 seconds to see if you can determine why I may have seen this fuel failure.
