RCU Forums - View Single Post - Comparisons of plug construction
Old 06-03-2003 | 03:46 AM
boater
Default Surface coat
Yes you are right I use PVA first. I don't thicken it enough to be a putty, I thicken it enough so it will not slide off the vertical surfaces, thin enough to let the bubbles out and still be fairly easy to brush. You can peel the PVA if you're too rough, but it's not much of a concern.
