RE: Redesign and reconstruction of the Oldest Taurus on Earth
But,
Sometimes I also have to do concessions on the color, in this care, black instead of white.
I did get the material from a friend to make the nose gear pivot points.
These points you find in every Taurus of that period.
Behind the axle of the nose gear I did drill a hole (1,5 mm) to feed through the wire to lock/seal the screws as I show for one of them. The wire, blue on the construction drawing, I solder against the head of the screws (green) with a (big) solder iron to prevent anti clockwise rotation. (Double security!)
Picture 4 my "blind nuts", soldered on a piece of epoxy printed circuit board with copper on one side. The back side I glue with 2 component epoxy glue on the bulkhead.
Picture 5 , construction drawing.
Cees
