RCU Forums - View Single Post - Will you look at this post
Old 11-10-2008 | 11:36 AM
erbroens's Avatar
erbroens
Default RE: Will you look at this post
Matt is the man to answer this.. meanwhile my educated guess is a fuel obstruction.
You may check the copper tubes wich usually are they that hold any residue wich can cause the fail, the fuel filter, a faulty solenoid or a too
loose connector on the ECU, a defective fuel pump, just to name a few causes that can cause this.
