RE: Will you look at this post
We had a P-60 do something similar, turned out to be some gunk in a filter
Be sure after you clean your lines and check everything to do a manual reset.
Sometimes after things like this, the motor will not achieve high rpm anymore and you need to reset by going to full throttle with the manual button held down.
