RCU Forums - View Single Post - Will you look at this post
Old 11-10-2008 | 12:35 PM
seanreit's Avatar
seanreit
My Feedback: (60)
Default RE: Will you look at this post
Keep in mind, if you had an obstruction that emtied the uat, but that obstruction caused negative pressure in the uat via the pump, the uat could have siphoned fuel through the obstruction while you were deadsticked, showing a full uat, but that there is really an obstruction.
Firing up the engine and running to full for a minute should repeat the problem if this is the case.
