RE: Elevator check...
If you are worried about the servo mounting plate coming loose, glue a piece of tri-stock to the plate at the bottom shelf. This will give more glue surface. Now laminate a piece of 6oz. glass cloth over the entire plate letting the cloth extend above and below the plate onto the fuse a couple of inches on each side.
