ok did you get the speed controller from us? what's your order number I can mail you one.
if you want to test the receiver and transmitter then simply plug a 6V battery into the battery slot. You'll need a speed controller for the system.
http://www.xheli.com/50brspco.html
Trottle to speed controller.
alieron to the servo that makes the swash tip left and right
elevator to the servo that makes the swash tip front and back
rudder to gyro
gear not used
aux 1 to the pitch servo
aux2 to the sense wire on the gyro
Andy
