RE: Ultra Sport 60 build
I’m using a lot of glue, a little bit too much I guess...
With this Aliphatic glue I work faster there is always something to glue as long there are free clamps method, about an hour since the last gluing
Glued the TE sheeting while it still pined to the TE jig, didn’t jumped the wagon this time.
Then wet the LE several times till it bent to fit and not soaked with water I glued the LE sheet, It held with clamps, tape and pins.
When The LE cured I glued the TE sheeting
