RCU Forums - View Single Post - Adding Counters to an SSE
Old 11-10-2008 | 10:05 PM
Deadeye's Avatar
Deadeye
Default RE: Adding Counters to an SSE
Sounds like a CG issue. Try moving the battery BACK, not forward. Go in 1/4 inch CG increments. My elevator is right in line with the stab, and inverted takes very little back pressure to keep level.
If that doesn't help, try shimming the bottom two mount holes of the engine mount with some washers or thin plywood.
