RE: Another Dynaflite Super Decathlon Build
Here are some more pictures. I have one wing panel mostly built, minus some final sanding and servo mounting. The die-cutting has been great. The wood is still a little on the heavy side, especially the ribs. The instruction manual could use a little tweaking. Be sure to read every item word for word and inside out or you will miss something. So far I'm pretty happy with how its going and can't wait to get started on the fuselage. (too bad I have to build the other wing panel first!)
Ribs and main spars in.
