RCU Forums - View Single Post - Space Walker Autogyro conversion.
Old 04-12-2002 | 11:15 PM
soarrich's Avatar
soarrich
My Feedback: (98)
Default Re: Space Walker Contraption
Originally posted by Gyronut
Mr. Soarrich
My point is that basically you have created something that is going to fold up on you during flight.....???? If you look at where the fuselage and rotor gimbal attachment bolts are they form 2 parrallel lines, in the horizontal plane and as the rotor drag increases these 2 area's are going to start pivot to the rear......
Me thinks you might want to add some front to back cross braceing to prevent this potential nightmare from happening...
I thought about that when I was building it, then forgot about it, thanks for pointing it out to me. I'll throw on a diagonal piece from the front to the back uprights. The pylon looks OK in the other axis kind of forming a triangle with the fuse as the base.
What size Hitec servo are you using....????
HiTec HS605BB I think it's 77oz of torque.
