RCU Forums - View Single Post - TF P47 .60 Balancing Act
Old 11-12-2008 | 03:13 PM
  #209
Craig-RCU's Avatar
Craig-RCU
Default RE: TF P47 .60 Balancing Act
Valves don't need much force to operate them, so a micro will have plenty torque and will save an ounce of weight but they are generally more expensive. I've used micro servos on air retracts before and that worked well. I'm using a standard servo for the valve on my P-47 and it is also working well. I guess it boils down to whether the extra expense of a micro is worth the weight savings to you.
