RCU Forums - View Single Post - Correct way to adjust servo....
Old 11-12-2008 | 05:27 PM
kens999
Default Correct way to adjust servo....
Hi,
I need to replace the servo controlling the rudder/tail wheel on my Hobbyzone Super Cub. After dropping in a replacement, can you please explain the method behind aligning the servo arm with respect to the rudder and tail wheel. I know the control rod has a threaded adjustment where it attaches to the rudder, but how do you determine optimum orientation when putting on the servo arm? Also, if adjusted properly, is the rudder suppose to line up perfectly to form a continuous plane with the front section of the tail (hope that makes sense) at neutral stick?
Ken
