RE: Baby 260 Build Thread
RCmaster12
Tower Hobbies carry the [link=http://www3.towerhobbies.com/cgi-bin/wti0001p?&I=LXDG59&P=7]Perry Pump Regulator[/link] , but unless you have lots of experience working with pumped engines you are looking at a lot of trouble. In my limited experience I can tell you, you may end up replacing the carburetor to make it work properly. For more information you can call Conley Precision Engines at 1-630-858-3160 and they can help you much better.
If you are only interested in pumping the fuel from a tank that is too far away from the engine. I will suggest you try a Cline Regulator from [link=http://www.billsroom.com/pcfs/]billsroom.com[/link]. It's going to be more expensive but it's a lot less hassle.
