RE: 1/2a Rivets Build!
well heres where I'm at. basically the top of the fuse is done. lotsa sanding! but thats cool forsure! Im going to have to go back to my LHS on friday to pick up some wood for the wing I forgot. and some servos, HS55's ?
vic, that cowl/scoop under the engine looks mean, I hope you dont mind if I copy it!!! also, how did you go about the dowel LE? sand a half circle in the front f the ribs? or is there a better way.
