RCU Forums - View Single Post - Problem with my OS 46FXi Engine
Old 11-12-2008 | 11:12 PM
alan0899
Default RE: Problem with my OS 46FXi Engine
ORIGINAL: blhollo2
Ok, so when i put the prop and spinner on my engine, it is very very hard to spin the prop, actually you cant even spin the prop with out having to muscle it it feels all tight and locked up.. i added some oil to the spinning portion of the engine but it still is tight ...what the heck is going on? HELPPPPP!
G'day Mate,
Have you taken the prop driver off, or did it fall off at some stage, if so, you may have lost the washer, that goes between the prop driver & the bearing.
It is a small black washer, & it must be used, or the engine will be locked up.
SO find that washer, & put it in place & you should be OK.
Look at your engine manual, & you will see where the washer goes.
