RE: Hobbico Voltwatch w/6.0v battery issue?
Your Volt watch is fine, this is normal. When you move a servo it draws current from the batts and their voltage will temporarily drop into the yellow zone, then go back to green. Don't try to run 6.0V with the switch set to 4.8V, you might damage it.
