RCU Forums - View Single Post - Ailerons work like elvons
Old 05-29-2003 | 05:18 PM
strato911
Default Ailerons work like elvons
Actually, you've got them setup like flaps. The easiest fix is to swing the pushrod to the opposite side on one of the servos, so it is a mirror image of the opposite wing. Since both servos rotate in the same direction when using a "Y"-splitter, you need to use opposing sides of the servos to achieve reversed travel on your ailerons.
