RE: Piston Alignment
It depends on which side of the piston that the ring gap is on as to which direction you have compression.
Four strokes are not critical about which way the piston is
But it is best not to disturb the ring postion in the cylinder
The rod goes in a certain way - there is a front side and back side
Always put things back like you found them.
