I have a tg-3 by Daves Aircraft Works and I am a solo learner and it has taken one to mamny hard landings and has broken the foam and what should I do? It is broke in front of the wing slot and in fround kinda in to 3 pices like the fuse,section1 and sec 2 and what should I do? I am going to try to spray it with the glue and tape it up with straping tape if that don't work... Think I could put the wings on a broom stick thats light and zip tie my radio gear on and cut a v out of the back of the handle and make it a v tail?
For Info on my plane can be found at
http://www.davesaircraftworks.com/thermal.htm
Then look for TG-3
Stormgald
