RCU Forums - View Single Post - How do you cut threaded rods?
Old 11-14-2008 | 09:22 AM
Birman
Default RE: How do you cut threaded rods?
I have quite a few threading dies. I first run a die on the rod and then cut the rod with a Dremel cutoff. I then file off the burrs and round it a bit and then work the die over the cut end. Works every time.
