RCU Forums - View Single Post - How much expo do you pattern pros use? If any
Old 11-14-2008 | 10:11 AM
PeterP
Default RE: How much expo do you pattern pros use? If any
Another method I have seen another top pilot use is as follows.
Adjust throws so that you have enough throw to perform the manouvers required at that particular rate switch setting. Once that is done adjust expo so that you have 50% throw at 50% stick travel and do that for all functions. This should give a good linear feel across all different rate switch settings.
