RE: Another AX46 Question
Yes, you don't need special tools. Just a screwdriver and a hex driver. To remove the bearings, you will need to heat the case. They'll just drop out when the case is over 200-250 degrees F. Heat the new case to install the bearings. Don't heat the bearings. They should be at room temperature during reinstallation.
