RE: How do you cut threaded rods?
What Walt says. You can get a wire tool with sections to strip, cut, crimp, and cut small bolts or threaded rod. They have one side with different size threads. The other side is large enough for the screw to pass through. Thread it to the correct length, make your cut, then when you back the cut screw out the built in die will clean up the threads. Has both standard and metric sizes. Less than $20.
