RCU Forums - View Single Post - How do you cut threaded rods?
Old 11-14-2008 | 11:59 AM
vicman's Avatar
vicman
My Feedback: (10)
Default RE: How do you cut threaded rods?
quote:
ORIGINAL: MinnFlyer
I just cut it and then touch up the end buy holding the rod against a belt sander at an approximate 60° angle while spinning the rod.
That's how I do it too!
Me too. sometimes I use a bench grinder.
Most threaded rod is super soft and can be fixed up with a flat file very easily.
I wouldn't use tin snips since the edged can get nicked easily screwing them up for fine cutting on sheet metal later.
