RCU Forums - View Single Post - Should I ask santa for a cherokee for a second plane?
Old 11-14-2008 | 03:18 PM
ChuckW's Avatar
ChuckW
Default RE: Should I ask santa for a cherokee for a second plane?
ORIGINAL: RCKen
There is one gripe I do have about the Cherokee that has come up after I finished my review. It's the wheel pant on the front wheel. There is a recessed hole that the end of the wheel axle sits in on the wheel pant. This keeps popping out and the wheel pant gets off center to the wheel. I might put it on the bench when I get some room and see if I can find a fix for it.
Same problem here. If the axle were just a hair longer or the plywood piece it sits in were a little thicker it might work a little better.
