ORIGINAL: sidav
hi quick question would you use a ar600 in a ic model cheers
You mean glo fuel? Sure I don't see why not if I only needed 5 channels or less. I'd most likely choose the AR6000 or 6200 if I wanted separate ailerons though due to most TX programs needing channel 6 for the second aileron.
