RCU Forums - View Single Post - Made it harder than I had to
Old 11-15-2008 | 07:36 AM
Wingdinger2
Default RE: Made it harder than I had to
I personally would recommend using ailerons from the start, but if you really don't want to, then at least plug the rudder into the aileron channel on the receiver, that way, your "aileron thumb" is learning it's job, and it'll make it completely painless to switch back to using ailerons later on, as you'll be using the same stick.
