RCU Forums - View Single Post - Tuning Problems
Old 11-15-2008 | 07:57 AM
pe reivers
Default RE: Tuning Problems
ORIGINAL: buddy072
Hi all I have the 90 size SK engine. My satisfaction with this motor has been very mixed. Break in on the bench seemed to be a non event, but once put into my plane, a Sportsman Aviation Paramount 60 I have had no end of trouble with tuning. The motor is mounted inverted, but I have never had a problem with inverted motors before. The low speed needle has been wound in quite a fair way to maintain a reliable idle but in doing this I cannot get the high speed needle set rich enough, after turning high speed needle out approx 4 1/2 to 5 turns the engine to try and get rich enough it all of a sudden goes lean and just dies. Now looking through the top of the carb my low speed needle has nowhere near a 1mm gap it actually has no gap and is in the spray bar if that makes sense. I am running a 14X8 APC prop and would run a 15X6 but I do not have the ground clearance. Oh also when flying when dropping back on throttle the engine makes a ring ding ding noise like a 2 stroke motor bike which some would say indicates too lean a setting on the low speed needle but if I try to richen it, it just loads up and stalls. Please any help would be appreciated
Cheers
Scott
If you set the idle lean enough, the idle needle blocks (restricts) the high speed fuel passage too much. You can use a small 1.5mm drill to drill out the spraybar almond eye full bore part to allow more fuel through at full throttle. Be careful not to drill in the idle part.
With this engine, be sure to use an OS-F plug. It is about the only plug that works well.
