RCU Forums - View Single Post - How much expo do you pattern pros use? If any
Old 11-15-2008 | 04:34 PM
patternflyer1's Avatar
patternflyer1
Default RE: How much expo do you pattern pros use? If any
Chad.. We fly the same mode I think. Ailerons Throttle on the left, rudder ele on the right?
As for Expo, I use 30% ailerons, 40-45 percent ele and rudder. And I use a dual rate switch for snaps and spins.. Not a snap switch though.
And I use less throw than Chad in the video. When I'm at knife, I am at about 90% stick travel. Pushes and pulls are also at about 90% stick travel.
Chris
