RE: 2nd Plane....How's this?
Your most recent link is the best, Andrew. Although it's designed as a second plane, keep in mind that it's a low wing and won't have quite the stability that your trainer has. You can get around that, though. The tricycle gear will help ease the adjustment, and the ARF builds quick and easily. RCKen did a review of this plane, and notes in his article that the Cherokee is a good aerobat, while remaining stable and forgiving in flight. Of course, the roundness of the fuse along with its attractiveness helps break with the tradition of the "box-like" low-wing trainer.
NorfolkSouthern
