RE: Modified Heng long Gear boxes
Top job YHR, looked in this myself but was unable to locate gears etc. If you haven't done this already, might I suggest you put 2 flats on the shaft to lock the gears in place & if there is room you could use 2 more small gears with teeth removed as locking collars on the outside of the gearbox thus holding GB housing together?
