RE: FUEL FOR OS120AX
I run a 120AX. The biggest difference you will see in using higher % nitro is more fuel consumption. You have to open the needle valve to let in more fuel as higher nitro burns in less oxygen. I find no need to use more than 10%; I think it's a waste of money and fuel. There is a slight increase in power with more nitro, but it's not very noticeable.
I think 20% you start to come close to timing issues and predetonation. YS engines use at least 20% nitro, but they are a different animal.
