A couple of weeks ago, I had an opportunity to fly the TF AT-6 ARF. It was powered with a O.S. 91. The builder of the model had excessive throws on the ailerons and elevator (he felt the instruction throws weren't enough). Once that was squared away, I flew the Texan and I must say, I was impressed with the way it flew. It was very solid and not twitchy at all. The stock retracts worked well, but they do look funkey. Landings without flaps is a no brainer as it slows nicely. It sure does look nice flying with the gear up! I just might have to get one of these birds, I'd strip it and use a different trim scheme though.
I would like to see Robart come up with a replacement gear.
R/C Foolish
Robart used to make a set of retracts for the TF AT-6 kit. They should fit without too much effort.
FB
