RCU Forums - View Single Post - Battery question
Old 11-16-2008 | 09:03 AM
OldScaleGuy's Avatar
OldScaleGuy
Default RE: Battery question
As far as the higher mah battery, that is no problem with regards to your other electronics. Changing the voltage is another issue altogether. Two things consider when going to a larger mah battery. 1st, will it physically fit in your helicopter? 2nd, will the added weight be too much for the heli to handle? Going from a 1200 to a 3000 is a considerable increase so just check and confirm the above otherwise you will be fine. You may want to consider a something in between 1200 and 3000 as well. As far as a balancing charger it is always good to balance charge your lipos. Starting out, I would suggest you shop around for an inexpensive one (there are some out there) that will charge a 2s pack and move up to a better charger later. I have a couple of inexpensive Esky chargers that work fine for the smaller heli's.
