RCU Forums - View Single Post - Modified Heng long Gear boxes
Old 11-16-2008 | 10:01 AM
Panther G
Default RE: Modified Heng long Gear boxes
the best way I have found too through drill some thing like this is to make a spacer the inner dimention of the object being drilled and clamp it in place. The spacer will act as a drill guid so your new holes are in alingnment. The spacer should be hard but not oo hard. A good block of oak or hard wood should work. You cab pre -drill the spacer as not too over heat the bit.
