Futaba 9z wc2 conditions help please
Don't have the WC2, but I have the WC1 and I assume they are nearly identical. No, there is not a global delete that I know of.
My guess is that at one time some model decided to create some default conditions. Heli setups do this I believe. You will have to check each model to find which one is claiming condition #11. Even a disabled condition can still be assigned to a model. Find out who is using #11 and remove the association of that condition from the model. I do not believe condition reset removes the association, it just resets the details of the condition.
OR, just use another condition. The order or numbering of conditions isn't critical... why not just pick #20 or something? Just copy the model default condition, say #2 to condition #20. Then in the model menu, assign condition #20 to the model. Then switch to condition #20 by whatever switch, slider, etc you assigned to the condition. Once condition #20 is active, you can name it in the condition menu under CNA.
Hope this helps. Cheers.
