RE: Wing rock?
you can raise the ailerons on the bird with a mix if you want to get it out. I use to do this by raising it about 1/8 to 3/8" on the average bird. I would do it with a 3d mix at full elevator throw both ailerons will rasie of lower to the direction of the elevator throw. I do not do this mix anymore I either correct the ailerons as it rocks, or I let it rock. I am not sure why I stopped doing the mix I just dont really want the mix in there anymore.....
