RE: jr 9CH RX SERVO LOCATIONS
I've had this transmitter over a year now. Everytime I set up a new plane, I start on page A-1 and just step through the setup as it progresses though this "A" section. You will find the following pages address your setup: A-10 inhibiting switches, A-11 Wing type(several choices you need to make here), A-14 Dual channel setups, A-25/26 Flaps. It is important to step through all the pages as you do your setup. Some of the choices you make along the way affect what capabilities you can perform(i.e. dual servos, dual channels, flaps, etc.) Oh, it would be really helpful to have the parts of the manual you need printed, unless JR is sending printed manuals now. I only got a CD for a manual. I printed the "G" and "A" pages as I only do airplanes. I also printed a second copy to carry in my transmitter case if I ever needed it at the flying field.
