RE: jr 9CH RX SERVO LOCATIONS
It really depends on how you program the transmitter. In the ACRO configuration the left aileron can be on channel 5, 6, 7, or 8. In the default GLID configuration the left aileron is on channel 1 and the right is on 2. The surest way to check where your servo locations are is by using the MONITOR menu. Channel 1 is the one in the upper left hand corner. Below that is channel 2, etc. The channel in the lower right is channel 9.
Allan
