RCU Forums - View Single Post - Charger is getting very hot while charging.
Old 05-30-2003 | 07:09 PM
Bax
Default Charger is getting very hot while charging.
Try the charger again on the 12V battery. If it's running cool, then it's the power supply. Some power supplies don't provide a good, clean source of DC voltage. A "dirty" supply will cause the charger to operate incorrectly, which could easily lead to overheating.
Now, if the charger still gets hot when you use a 12V battery, then we'd agree that the charger has a problem.
Just some things to consider.
