RCU Forums - View Single Post - Nitro Engine Troubleshooting and Tuning
Old 11-18-2008 | 10:10 PM
  #32
chevyderek72's Avatar
chevyderek72
Default RE: Nitro Engine Troubleshooting and Tuning
ok what you need to do is put the fuel line to the carb on, then take off the fuel line that goes to the pipe and blow in it, it will push fuel to the carb, right when fuel hits the carb stop blowing. then put a couple drops of fuel in the carb. then make sure your settings on your carb are fine. put the hsn at 2.5 turns out, and the lsn flush with the collar. those are base settings so tune from there. then it should start up. if it doesnt start up i hold the car down with the radio, and pull the throttle, put the glow ignitor on, and then pull start it, it gets more fuel to the carb and that way it will start if its being stubborn
