RE: Help with rust in engine
All you have to do is put acouple of drops of coolpower or klotz oil down the carby after flying andturn it over a few time to protect the motor. Also a good idea to run the fuel out of the engine at the end of the day ie drain any fuel from the tank and then start engine up like normal, should run for a few seconds and then splutter out. Is a good idea
