RCU Forums - View Single Post - Walbro conversion for OS 160FX
Old 11-19-2008 | 05:23 PM
  #32
liquid_TR's Avatar
liquid_TR
Default RE: Walbro conversion for OS 160FX
Thank you Benoit,
Ok Here's an update on the project:
Im going with a walbro carb conversion for this project, as it has a diaphram pump and regulator on it and meters easier than glow carb.
Actually Ive run into a problem today. I received my package of walbro carb, gaskets and adaptor flange for EVO26.
The flange has a 17mm outer diameter throat and 160FX has a throat of 15mm. so unfortunately its not a bolt-on fit..
The good news is the walbro carb clears the thrust washer so it wont be a problem once I sort out the adaptor flange.
On another note, this engine with gasoline is doing fantastic!
Here's a couple of RPM readings (with glow carb) you all will enjoy:
All with Bisson Pitts muffler - same day, same fuel.
using single 1500 mAh LiPo cell to power RCExl ignition.
APC 17x8 - 8400 RPM
JXF wood 17x8W - 7800 RPM
JXF wood 18x8W - 7400 RPM (unbelievable thrust!)
The transition is incredible even with 18x8.. no lag what so ever, can idle around 1600 rpm with ease..
I will upload a video of the engine running soon.
I also want to say, one of these conversions will be used with a MVVS 26CC tuned pipe. I bet the numbers will go up even more!
This might turn out to be the best 26CC conversion.
Im still using the 7:1 oil ratio gasoline, buy I will drop to 10:1 once I sort out the walbro adaptor and report back with all the tach readings.
